Python ANSYS Optimization
Old   November 9, 2020, 10:50
Default Python ANSYS Optimization
lizaf123 is on a distinguished road
I am planning to work on a project to couple ANSYS and Python to automate the Design Exploration task. I am also thinking to use a GA to optimize the geometry.
Outline as follows:
1.Parametric model in ANSYS Spaceclaim/DM
2.Model is automatically meshed
3.It is then fed into Fluent to obtain the results which are written to an output file. (Batch mode)
4.The python code reads the output from the file and calculates fitness.
5.Does Crossover mutation etc.
6.Writes the new parameters to an input file.
7.Which is then read by Ansys, steps 1-6 are repeated until convergence.
Please note the geometry is modified in each generation of GA.
Is ACT a good option for this, and I don't quite understand the journalling method?
Also, I am a beginner and would like to know how to proceed with the problem? It would be great if you could share the source code of any similar project?
Thanks in advance
lizaf123 is offline   Reply With Quote
Old   August 12, 2021, 05:19
coyote
coyote is on a distinguished road
Did you achieve to automate fluent with pythonn finally ?
coyote is offline   Reply With Quote
ansys 2020, optimization, parameteric analysis, parameterization, python script
ANSYS Optimization failing to update Results component. harmollo1 ANSYS 1 March 21, 2019 15:30
Optimization study with ANSYS CFX (FLUENT) and MATLAB rusham ANSYS 0 January 25, 2018 04:54
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
Change the python file with shape optimization 454514566@qq.com SU2 1 July 19, 2014 13:21
Parametric runs and Optimization in ANSYS (Conjugate Heat Transfer Problem) cp_jef ANSYS 0 May 30, 2011 04:08
