ANSYS Icepak - PCB Thermal Analysis
Old   March 7, 2021, 16:44
Lightbulb ANSYS Icepak - PCB Thermal Analysis
Gabi
gbartolome is on a distinguished road
I am doing thermal analysis on a PCB for a senior design project. I used ansys icepak, but I think that the model output/analysis is incorrect given the high temperature on only 1 resistor. The temperature distribution looks incorrect is what I am saying. The PCB is an inverter with 5V running through it.
My question is do traces generate a lot of heat in PCBs? If so, is it enough to need to put into an ANSYS Icepak model? How do I do so from Eagle Autodesk STEP file or.brd file? How do I make my model better? How do I ensure my model is converging on a solution? If I use a thermocouple to see the power dissipation on each component, can I change the power dissipation on my model in order for it to be more accurate?
gbartolome is offline   Reply With Quote
icepak, pcb, thermal, traces
Hand calculation for Junction temperature. PCB thermal analysis using excel. cfd_user_pune System Analysis 1 October 2, 2021 09:20
Hand calculation for Junction temperature. PCB thermal analysis using excel. cfd_user_pune Electromagnetics 0 February 28, 2021 01:51
FSI Transient Thermal Analysis Abduri CFX 1 January 1, 2017 22:54
Ansys thermal analysis snehpatel0964 Fluent Multiphase 0 July 11, 2016 07:00
[ANSYS Meshing] steady-state thermal analysis in ansys workbench zenwalk ANSYS Meshing & Geometry 3 March 19, 2012 21:40
