ANSYS System Coupling Interrupt/Abort Problem
Old   June 7, 2021, 14:54
Exclamation ANSYS System Coupling Interrupt/Abort Problem
Oğuzhan Demir
ddemiroguzhan is on a distinguished road
Greetings,
I am trying to make a 2-way acoustic FSI in Ansys workbench. After I have set the problem up, when I started the calculation, no errors occur. But, after a while, when I try to stop the analysis (to check the interval data that is written by the acoustic probes which are specified in Fluent part), it does not stop. I have tried to use ctrl+c, also tried to shut the processors from the task manager (mp_fl...exe) but it did not work.
Also, sometimes it stops without a warning. I mean, the analysis seems to be going but the data is not written after a specific time. And that specific time changes every time this problem happens, so it is not likely to be causing from the time-step or the analysis itself.
If you have any suggestions about how to prevent Ansys system coupling analysis to stop without a warning but seems to be going, I'll appreciate it very much!
Thanks in advance,
Note: Analysis is running as parallel on my PC.
Oguzhan
ddemiroguzhan is offline   Reply With Quote
Problem in coupling CFX and Ansys for fluid-thermal sim. Jordi CFX 21 March 1, 2017 05:03
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 05:57
Re meshing in system coupling Ansys ramidalf FLUENT 0 January 12, 2015 13:33
Ansys Workbench Thermal-Stress Coupling - 2D Hot Rolling simulation Jeronimo97 CFD Freelancers 4 August 23, 2014 20:30
How can I track the progress of FLUENT when running ANSYS System Coupling yhy20081016 FLUENT 1 June 4, 2013 12:03
