November 22, 2023, 16:58 |
Thermal analysis
samuel hanna
Rep Power: 2 |
I want to perform a 3D model of concrete frame exposed to fire and compare results with test of the same frame in furnace
My questions are: 1. Use transient thermal or steady state thermal? 2. Applying of temperature with constant value i.e. 100 °C or apply time temperature curve such as iso 834 curve or Eurocode curve? 3.How can i find the element type solid 70 in ansys? |
November 30, 2023, 11:17 |
Erik
Rep Power: 23 |
Nobody will be able to help you with that vague of a question. What are you trying to compare to experiment, transient behavior or steady state behavior? We have no idea what you are trying to do.
November 30, 2023, 11:49 |
samuel hanna
Rep Power: 2 |
I want to compare thermal analysis with test results
Importing solution from thermal steady state analysis to transient analysis | david_1995 | ANSYS | 0 | July 31, 2017 05:54 |
Can openfoam conduct 3-D thermal bridge analysis? | Mark JIN | OpenFOAM | 4 | June 22, 2017 08:39 |
analysis the photovoltaic thermal collector (PV/T) by Ansys and Radiation modle | ali.alshamani | FLUENT | 0 | March 16, 2014 00:40 |
Sustained thermal stresses from FSI analysis | Hamjaj | ANSYS | 0 | May 10, 2013 11:26 |
thermal analysis | raffap | Siemens | 7 | May 23, 2011 02:08 |
