Where do you save your projects?
Old   February 11, 2024, 03:19
Default Do you take SSD TBW in consideration?
user628 is on a distinguished road
Do you take SSD TBW in consideration, SSD has around 150 - 300 TBW?
CFD projects can be big so is it practice to save projects on HDD in CFD engineering or that slow down work too much even if program is installed on SSD?
user628 is offline   Reply With Quote
Very quick - Journal file command to save monitors lcaBR FLUENT 2 October 18, 2022 12:26
Urgent:error regarding save chodvadiyaharsh FLUENT 2 January 18, 2022 14:45
Help merging workbench projects gtarroyo ANSYS 1 May 19, 2021 05:39
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
save case & data Saman95 FLUENT 1 August 12, 2018 06:09
