Question about the constant Temp. of Transient fluid-thermal two-way coupling |
March 6, 2024, 00:24 |
Rep Power: 3 |
Dear all,
I want to calculate the transient temperature of watering cooling solid with internal heat source. I try to use transient two-way coupling calculation (please see 1.png). The external data module is used to import the thermal generation into the transient thermal analysis module and set the analysis time with end time as 10s, the time step as 1s, the time integration as on, and the analysis time in the imported heat generation as 10s (please see 2.png and 3.png). The transient two-way fluid-heat coupling calculation was performed combined with the iteration of results of the transient fluent calculation (fixed time step 1s, 10 steps in total) and the iteration of the results of the transient thermal analysis module. In the system coupling module, set end time as 10s and step size as 1s. My question is why the resulting temperature in the transient thermal analysis module does not change with time after the coupling calculation but is a constant value (please see 4.png). Do I miss some settings, thank you very much. I have attached the settings pictures in the attachment. Thanks in advance. |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
