April 8, 2024, 10:15 |
Residuals aren't converging
Brendan
Hi ,
I am currently trying to run simulations on a fin and streamline tube heat exchanger with 2 million cells and I am facing an issue with the residuals not converging. Boundary Conditions 1. K-Epsilon Model 2. Air and Hydrogen-liquid 3. Mass Flow Inlet 4. SIMPLE 5. 1e-08 6. Hybrid Initialization 7. 2000 iterations If anyone can let me know what can I do for better residuals would be really helpful |
April 11, 2024, 09:34 |
Gert-Jan
Rep Power: 27 |
1. I would ask the Fluent Forum
2. What is your Re-number? K-epsilon is for high Re numbers. Better use SST. 3. Your flow problem will have transient features. You'll never be able to obtain a steady state solution. 4. If you want a steady state solution, limit you geometry to a very thin gap that slices the obstacles in half. |
April 11, 2024, 09:55 |
Boundary Condition
Brendan
I used a mass flow inlet with the following variables..
Air 1. Mass Flow = 11.25 2. Gauge Pressure = 105700 3. Temperature = 344K Hydrogen 1. Mass Flow = 0.1022 2. Gauge Pressure = 1571000 3. Temperature = 24K |
April 17, 2024, 03:45 |
Gert-Jan
Rep Power: 27 |
What do you want to say with this reply?
Why are all but do-intensity residuals converging? | _martin_ | FLUENT | 0 | February 19, 2024 10:39 |
Residuals not converging | thorbo | FLUENT | 1 | November 1, 2023 08:36 |
Residuals converge initially, then stop converging | andrew-c | FLUENT | 2 | April 6, 2023 12:12 |
Pimplefoam - residuals not converging | cyln | OpenFOAM Running, Solving & CFD | 16 | November 7, 2017 12:46 |
strange residuals - converging -then diverging- then oscillating - then getting weird | juste | FLUENT | 3 | December 3, 2016 17:26 |
