Steffen Heidrich
Rep Power: 15 ![]() |
what I am trying to do is model heat transfer in air gaps. Example a double glazed window, different temperatures both sides. What can Ansys do, and how? Tried CFX, but could not work out how to assign the temperatures to the boundary surfaces. Cheers, Steffen |
Neil Duffy
Rep Power: 16 ![]() |
Hi Steffen,
I assume you are talking about Fluent as both CFX and Fluent are now part of ANSYS. In CFX, to set a temperature to a boundary condition (BC) go to insert-boundary (It will also appear on the toolbar as a box with 2 arrows). You'll need to set your BC to a "wall". you should then be able to specify temperatures, emmisivities etc. Regards, Neil |
Steffen Heidrich
seems its just surface properties you can assign for the wall....
Rep Power: 17 ![]() |
That's right, if you are just doing CFD, then it will only allow you to assign values to the boundaries.
It sounds like you are interested in a conjugate heat transfer problem. In that case, you would need to like a Thermal analysis to CFX. Then the temperature of the solid-liquid interface becomes part of the solution. Temperatures or heat fluxes can be applied to the boundaries of the fluid and solid regions. |
Steffen Heidrich
its just, could not find, how to assign temperatures in Ansys. Only surface roughness and velocities. What I am trying to do is natural convection, different temperatures both sides of the air gap and this will start to make the air move. Then see how it behaves with different thicknesses of the air gap.
Michael P. Owen
If you can't see where to assign boundary temperatures it's because you are using an Isothermal energy equation. Switch it to Thermal Energy on the Fluid Models tab of the Domain definition.
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
convective heat transfer coefficient | Fluu | Main CFD Forum | 3 | April 15, 2008 07:37 |
UDF convective heat transfer correlations | sarah | FLUENT | 0 | March 29, 2007 09:52 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
