Wind Turbine on FLUENT
Old   September 27, 2011, 11:18
Default Wind Turbine on FLUENT
federvo.mala is on a distinguished road
Hello everybody,
I am new to the forum and just started entering the field of CFD. Please be patient with me
For my bachelor thesis I will be working with the CFD study of a Wind Turbine.
I have a few questions:
1) It is possible with ANSYS Fluent to model a rotating Wind Turbine, right?
2) Is Fluent the best option?
3) I just requested an account number for accessing and downloading the tutorials from the ANSYS student portal, is the material going to be enough for my work?
Thank you very much.
Fed
federvo.mala is offline   Reply With Quote
Old   September 28, 2011, 04:08
ngoctm is on a distinguished road
Hi federvo.mala,
1. yes, that right! You can use ANSYS FLUENT to modeling wind turbine.
2. May be Fluent is the best CFD software for your problem. But, you can also use ANSYS CFX and other CFD software.
3. With the tutorials from the ANSYS student portal, I think that you can understand more about Fluent and may be to modeling your problem. And you can to practice more tutorial Fluent in its help.
Good luck.
ngoctm is offline   Reply With Quote
Old   September 30, 2011, 17:08
James
VU_Engineer is on a distinguished road
Yes, FLUENT is an excellent tool that is capable of solving your problem
worked on similar problems myself
unfortunately, license expired and now I'm trying to figure out Abaqus
let me know if you have any questions
VU_Engineer is offline   Reply With Quote
Old   September 30, 2011, 17:22
Hello guys,
thanks for your replies and your interest, really appreciated it.
So, I have been doing some tutorials and looks like that to make my three-bladed turbine rotate I need to use UDF, is that right?
I actually thought, that making something move was more straightforward.
Old   September 30, 2011, 17:24
James
yes, a simple UDF for rotation is needed.. pretty straightforward
Old   October 3, 2011, 15:10
Default Hi
leela
leela is on a distinguished road
I am leela. I am doing masters in mechanical engineering. I am planning to doa similar project "to show the motion of the air when it goes through the turbine". Could you please advise whether its good to go with ansys fluent or cosmosworks for cfd. I do have little bit of modelling experience in solid works .I am completely new to ansys.
Regards
leela
leela is offline   Reply With Quote
Old   October 5, 2011, 15:55
Regards
leela
Hello leela, it seems like we are doing a very similar project and our starting point is the same, like you my previous experience was Solidworks and also Abaqus.
To be honest, I don't know what the difference b/w the two packages are, but I would use FLUENT just for the fact that you get lots of tutorials and assistance from forum like this.
Old   October 5, 2011, 15:59
Hi VU_Engineer,
can i use singe/multiple rotating reference frames for studying flow through wind turbine? Or UDF is the only way? Can you please tell me a bit of what I should look at for UDF's regarding my problem?
Thanks for sharing your knowledge
Old   October 7, 2011, 10:10
Default Modelling the gemometry
leela
Hi Federico Malatesta
I am lavanya. Thanks for the reply. How did you model the geometry.I mean i came to know that we should model in such a way that it should virtually perform in real life condition
.I mean what have you taken in to consideration while modelling ??I am pretty much confused of how to proceed??
Old   October 10, 2011, 09:30
Hello, sorry but I am still trying to figure this out.
Old   October 18, 2011, 20:43
Thomas
solobang is on a distinguished road
Hi, Leela and Federvo.Mala. I am also study for my master degree with research topic on the wind turbine wake flow modeling. Unfortunately, I have very little on the fluent and solidwork. My previous experience is mainly related to UG and Ls_dyna. I have question as Leela. How did you model the turbine?
Bang
solobang is offline   Reply With Quote
Old   October 31, 2011, 19:10
James Hetfield is on a distinguished road
Bang
Hi
Im about to start my master's thesis which is CFD simulation of a wind turbine using Ansys fluent
can anybody send me blade geometry for wind turbine?
James Hetfield is offline   Reply With Quote
Old   October 31, 2011, 19:20
Originally Posted by James Hetfield View Post
Hi
Hello there,
as for the modelling of the wind turbine, can you guys please more specific? do you want to know about meshing? boundary conditions? or the simulation in FLUENT itself?
@James
i am using the the the blade used in NREL Phase VI Unsteady experiment so that I can also use the experimental data to compare. Just google it, you will find a PDF file. Other than that, google everything or contact companies.
Guys, since we are all doing kind of the same project, we're almost at the same level, i.e. beginners, let's try to help each other, so let's post questions, concerns and answers etc etc
Old   October 31, 2011, 19:25
Hello there,
@James
I need the geometry file itself
i need the file containing the blade modeled in workbench or whatever
Old   November 1, 2011, 22:03
Thomas
Hello there,
@James
Thank you James. I could not more agree with you. We should keep touch!
Old   February 2, 2012, 08:55
sanchovg2 is on a distinguished road
haha. very nice. i´m doing also my master thesis about the same wind turbine simulation. and i wanted to know how it worked for you doing the simulation.because im having some trouble generating the streamline and the wake flow.can some of you help me?
sanchovg2 is offline   Reply With Quote
Old   February 2, 2012, 11:16
Orb
Orb is on a distinguished road
Which do you mean by rotating a turbine...
Do you want the air to move the turbine
--OR--
The turbine to move the air?
Orb is offline   Reply With Quote
Old   February 3, 2012, 06:50
thank you for the quick answer
hi, i want the air to move the turbine.but i read that ist complicated and its easier to give the velocity from the air and to give a rotion rpm for the turbine.
in the velocity vector plot i dont see the vortices that are supposed to be generetad by the fluid flow after a body.because the stream lines are a representation with lines of this vortices.isnt it? or im wrong :s ?
I design myself a wind turbine in pro e with some data and studies i fond on the internet.the wind velocity is 8 m/s and the rpm are 22.5
So what i did was to put the velocity with a normal velocity inlet and the rotation i did it over the reference frames and the gave rpm.
I extracted the turbine from a small circular volumen and then this one from a bigger fluid area. i connected the circular volumen and the fluid volumen with 2 interfaces.
the first one the circular front/back is an In place-FAN interface and the second one is the other area and i did it with an In plane-Baffle Interface. Then i said that the turbine region should have an tagential velocity specification method: none and reference frame absolut. im not sure if it works this way for the rotion and the flow from wind.
the physics models that im using: 3D,Steady,Ideal Gas,Segregated flow,turbulent,K-epsilon T. and im runing another simulation with Stadard Spalart-Allmaras (eddie). but im not to familiarized with this turbulenz modell.
i also wanted to ask something like this is possible with star ccm+
http://www.youtube.com/watch?v=nj_iL8PXOD8
Old   February 7, 2012, 07:57
If anybody is interested I have posted a single moving reference frame setup in FLUENT on other post with screenshots. It works except for little things.
http://www.cfd-online.com/Forums/flu...tml#post343108
Best,
Fred
Old   February 1, 2013, 04:56
Default vertical axis wind turbine
  #20
maruthu
maruthu is on a distinguished road
what are the boundary geometry conditions to analyze a verical axis wind turbine in 2d.
pls tell where should be the in let and the outlet
maruthu is offline   Reply With Quote
tutorials, wind turbine
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Torque of wind turbine simulation caohan FLUENT 8 August 11, 2014 23:01
How to define rotational direction for wind turbine caohan FLUENT 5 October 10, 2012 05:43
Can I use Turbogrid to mesh a wind turbine blade? Henry Liu CFX 10 November 10, 2011 05:41
Modelling of 2D Wind Turbine Blade (HAWT) Richeom FLUENT 1 August 11, 2010 04:18
