How can I set turbulence and viscosity configuration????
Old   November 24, 2011, 04:28
Default How can I set turbulence and viscosity configuration????
sunti
sunti is on a distinguished road
Hello
I need to run a simulation of an antenna mounted to the belly of an aircraft. The aircraft is cruising at 140m/s at 2000ft. Which turbulence model would be suitable for this case?
I would also like to know how to estimate the turbulence intensity and freestream viscosity ratio.
Thankful for any suggestions!
sunti is offline   Reply With Quote
Old   December 20, 2011, 01:50
sunti
suggestions anyone?????
Old   December 20, 2011, 06:38
k_k
Kailash
k_k is on a distinguished road
This might help you,
http://www.cfd-online.com/Wiki/Turbulence_intensity
http://support.esi-cfd.com/esi-users/turb_parameters/
k_k is offline   Reply With Quote
Old   December 21, 2011, 02:54
sunti
Thank you so much.
This help me got the turbulence intensity and viscosity ratio and maybe my simulation can run without any problem.
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 15:39
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
