Shell element in squeeze film analysis of MEMS?
Old   January 6, 2012, 04:35
Default Shell element in squeeze film analysis of MEMS?
iskandar is on a distinguished road
Hi!
I'm doing the analysis of squeeze film effect on MEMS devices. Squeeze
film analysis simulates the effect of fluid in small gaps between fixed
surface and structure moving perpendicular to the surfaces.
Currently, I modeled the moving structure with the SOLID186 element. I
overlaying the FLUID136 element on the below surface of SOLID186 to model the fluid domain. Then I used the FLUID138 element to model the pressure drop through holes in moving structure.
Now, I try to model the moving structure by using the SHELL element.
But I have got some problem when to model with the FLUID136 and FLUID138 element.
Is it possible to using the shell element? Or you can give me any comment about that.
Thanks in advance.
iskandar is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
coupled field in shell model analysis chenwen521 ANSYS 0 September 28, 2009 22:32
FSI for shell element Edison CFX 0 December 21, 2007 00:58
