March 12, 2012, 06:04 |
ICEM bunching law exponential 1
Sascha
Hello everyone,
i want to analyse the influence of the mesh on the result. Therefor I created some meshes with different numbers of nodes. For the O-Grid in the tube I want to keep the ratio constant and change the y+ value. The Bunching law of the O-Grid is the Exponential 1 law. In the ICEM Help Engine I found the following equation to calculae the distance from the starting end to node i: S_i = Sp1*i*exp(R*(i-1)) with R= -log((N-1)*Sp1)/(N-2) S_i is the distance from the starting end to node i, Sp1 is Spacing 1, N is the total number of nodes, and R is the ratio In my case N is 38 and SP_1 is 0.002mm. So in my opinion S_38 should have the same value as the length of the edge wich is 22.5mm. But when I calculate S_38 with the above-named equations the result is S_38 = 0.2429mm. So what I wanted to do, is to change the total number of Nodes N and let the Ratio R constant. With these equations I wanted to calculate the new value for Sp1. But there seems to be a mistake in these equation. Can someone help? Thanks in advance |
ICEM Edge Params Bunching laws | twsloss | ANSYS Meshing & Geometry | 5 | May 28, 2020 13:04 |
PEM Fuel cell module meshes. ICEM vs workbench | aarvay | FLUENT | 24 | March 2, 2020 06:50 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
