Home > Forums > Software User Forums > Autodesk Simulation CFD
rotating region analysis, should rotating component be subtracted
Old   December 12, 2012, 15:39
Default rotating region analysis, should rotating component be subtracted
jpc
JPConway
jpc is on a distinguished road
in the help file it has an impeller example
it looks as though the impeller has been subtracted from the rotating region
http://wikihelp.autodesk.com/Simulat...1-CCD16D349875
however the sample files don't include that subtraction and i don't see that in the recommendations.
does anyone know if the help file is just not correct?
jpc is offline   Reply With Quote
Old   December 12, 2012, 15:41
jpc
JPConway
for anyone running this type of analysis, this is an interesting find:
http://usa.autodesk.com/adsk/servlet...inkID=18154757
Old   December 24, 2012, 12:24
Chris Fisichella
fisichel is on a distinguished road
Hi JPC,
If I remember that example correctly, the impeller is subtracted in CAD, but then Simulation CFD detects the closed volume and fills it for you. In Simulation CFD, you define the material for that new volume to be something other than a fluid and the code will calculate the flow around it.
It's sort of a back-door way of getting geometry into the model, but I can see why they do it; the captured volumes exactly match the fluid that surrounds it.
HTH,
Chris
fisichel is offline   Reply With Quote
Old   January 4, 2013, 13:52
jpc
JPConway
if you're using the cut-out method, would the cut-out be from the main fluid volume or from the rotating region?
it seems like the rotating region should be a full cylinder and then the geometry that is rotating within it either solid within the main volume (and the rotating region) or a cut-out from the main fluid volume (and within the rotating region). but that isn't what i'm seeing in this screenshot
http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0726-Guidelin726/0765-Rotating765#GUID-982DE07C-29A7-4056-A40F-B4911028CFBE
i used a solid rotating component, full cylinder rotating region and it seemed to work ok. that was closer to the models that came with the software but different than how it shows in the tutorial. in the tutorial it seems as though there was a cutout, that was filled and it gets selected as the solid. http://wikihelp.autodesk.com/Simulat...9-39A86207D30D
that being said, i think one of my original key failures was having a cutout AND having the solid which caused crashes during meshing.
Old   January 4, 2013, 20:43
Chris Fisichella
Hi jpc,
When I did that example, I was using Pro/Engineer and saw how they used a boolean subtract operation to remove the impeller from the rotation region volume. I also originally would explicitly put in a solid impeller, but that turns out to be unnecessary.
With regards to your first question, the impeller cutout should be from the rotation region. Or, at least that is what I have had success doing.
I'm glad you got it to mesh. Good luck with your analysis. It sounds like you are almost there.
Old   January 9, 2013, 16:04
jpc
JPConway
any chance you have the CAD files that you could send me? i can pm a dropbox. i'd just like to take a look at the pro/e and solidworks files. (i just deleted the software from my computer) i swear that there were no boolean ops in either the solidworks or pro/e files.
in case someone finds this, it sounds like the options are:
1. keep the solid that will rotate, generate a rotating cylinder which will also be a solid that overlaps both the main fluid volume and the rotating component. apply rotation to the rotating cylinder. (i had success with this)
2. subtract the rotating component from the rotating cylinder. the rotating cylinder will only overlap with the main fluid volume. autodesk sim will fill in the solid (and it must fill in the rotating cylinder). apply rotation to the rotating cylinder. (fisichel had success with this)
Old   January 11, 2013, 08:12
Chris Fisichella
Hi jpc,
I can't post the CAD. I'm sorry. I grabbed a screen shot, however, that shows how they built their model. I noticed there were two features on the tree. The first was the protrusion and the second was a cutout. I edited the cutout so you could see they selected the impeller to be subtracted from the rotating region.
HTH,
Chris
Old   January 11, 2013, 09:40
Mark Decker
marktm250xc is on a distinguished road
If an airtight void is detected, it is filled and assigned a new volume during launch. Some versions of ProE in the past were very, very finicky ... if you left the impeller in, the launch or meshing would at times fail. But if you took it out and let CFdesign create a new volume, the launch would succeed.
As far as meshing the impeller, there used to be an issue in that if you did not mesh it, you would not get torque values. Pretty sure that is fixed now. However, if you choose not to mesh the impeller, animations may not appear correct.
marktm250xc is offline   Reply With Quote
Old   January 11, 2013, 16:56
jpc
JPConway
hi fishchel, well that shows it. i wonder if i was just looking at something incorrectly. if i get a copy of the software or try the trial again, I'll check again.
any idea what you're supposed to do if you have a solid? if you should cut the solid from the rotating region so that it is equivalent to what you'd have if you had a void cut out of the rotating region?
Old   January 12, 2013, 13:59
Chris Fisichella
Hi jpc,
Yes, that would be a great first start. I started with a more real impeller. I then created a rotating region around it and I used the exact same subtract operation that AutoDesk uses.
When I brought it into SimCFD, I did not bring in the impeller, since I already had it cut out. The software filled it in for me. It looked exactly the same as the impeller I originally started with, as you would expect.
Good Luck,
Chris
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 09:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
rotating "wetted" surface region C-CARE CFX 10 February 18, 2004 03:37
