Home > Forums > Software User Forums > AVL FIRE
dual fuel(RCCI engine)
Like Tree1Likes
  • 1 Post By amin_u50
Old   September 19, 2013, 01:32
Default dual fuel(RCCI engine)
amin u3fi
amin_u50 is on a distinguished road
hi dears...
I am simulating dual fuel DME/CH4 with AVL FIRE 2011. I couple Chemical kinetics with CFD for this simulation and Spray mode is active in this simulation. the start of injection is 15CA BTDC. when my simulation arrive in start of injection the calculation doesn't progress and the last message in .fla file is:
%fire-W-cyveloc, U velocity is limited with 2000 m/s from current velocity=24658.8 m/s for Droplet No.=1
For Spray momentum coupling Momentum Source = 1 is recommended ! Momentumratio (Spray/Gasphase)=0.00000
%fire-W-cyveloc, W velocity is limited with 2000 m/s from current velocity=-5386.16 m/s for Droplet No.=1
%fire-W-cyveloc, V velocity is limited with 2000 m/s from current velocity=-2.083323E+07 m/s for Droplet No.=36
For Spray momentum coupling Momentum Source = 1 is recommended ! Momentumratio (Spray/Gasphase)=-1.4889
I need your help for solve this problem...
amin_u50
best regards
Tarig277 likes this.
amin_u50 is offline   Reply With Quote
simulation Dual Fuel engine with AVL FIRE Hoursfer AVL FIRE 18 October 9, 2023 15:44
Simulation of syngas-diesel dual fuel combustion with AVL FIRE bahaaddein AVL FIRE 1 January 28, 2013 06:19
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 22:19
recover solution from dual grid jamesproctor Main CFD Forum 0 July 30, 2010 15:31
Combustion modelling of dual fuel engine ?? ashishashish_5 FLUENT 1 January 18, 2010 20:42
