July 7, 2015, 12:38 |
Mixing two gases in a valve
Hi everybody,
I would like two know how to mix two different gases, each one with its own inlet, into a valve in a complete mixing. I was told to try with multiphase module but so far i couldn't find a way to resolve this problem. Thanks in advance. |
July 9, 2015, 09:48 |
#2 | |
Venkatesh V
In the inlets you can specify the mass fractions for the gases you like. |
July 16, 2015, 10:32 |
Thank you so much, but still now i'm not able to to get proper results. I am using the general method to indtroduce the composition of syngas (O2,H2,CH4,CO,CO2,N2) like species and the i set the molar fraction in boundary conditions but it always diverge. I tried changing underrelaxion factor or equations but it is useless.
Thanks. |
May 20, 2016, 03:47 |
Zvonimir
Rep Power: 10 |
Check mesh, then relax a little your time discretisation.
It diverges in which equation? It diverges suddenly or in some time? You can alway put your *.fla file or at least par of it... BR Z |
2D simulation for mixing two non-reacting gases | arun.mechie | FLUENT | 17 | August 3, 2016 08:31 |
rhoReactinBuoyantFoam - Buoyant Mixing of two gases | rkc.cfd | OpenFOAM Programming & Development | 0 | July 13, 2014 13:09 |
Modelling an initially closed valve which a fluid opens | siw | CFX | 1 | April 26, 2014 06:32 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
Floworks: Mixing and thermal analysis of two gases | Jay Nelson | Main CFD Forum | 0 | June 14, 2005 18:29 |
