Home > Forums > General Forums > CFD Freelancers
Reducing velocity of Ahmed body simulation.
Old   February 8, 2017, 17:40
Default Reducing velocity of Ahmed body simulation.
Lewis Shutler
Lewis1 is on a distinguished road
Hi there,
Relatively new to CFD,
Small problem that I have involves scaling down the known case of an Ahmed body running at 40m/s in fluent and trying to create simulation at 10m/s where it can still be considered valid.
I have carried out a simulation on the 40m/s case and have got an accurate solution compared to experimental data but am not sure if I could edit mesh to suit 10m/s free stream while still having some certainty that the solution is ok. I was using the k-epsilon model with non equilibrium wall functions on the 40m/s but I don't think it would work for this lower Reynolds number case.
Any tips?
Thanks.
Lewis1 is offline   Reply With Quote
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Ahmed body simulation alenglaro FLUENT 21 March 9, 2016 05:19
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Ahmed body -Drag coefficient not converging!! sam92 FLUENT 9 January 14, 2014 14:00
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 13:55
