Home > Forums > General Forums > CFD Freelancers
Driven/Travelling wave vibration of a flat plate. FSI problem.
Old   June 20, 2017, 06:02
Default Driven/Travelling wave vibration of a flat plate. FSI problem.
Rahul
raynorshiene is on a distinguished road
I am trying to simulate the flat plate and fluid interaction, however, unlike most of the cases, the "vibration" is a continuous sine wave.
In the experiment, the flat plate is meant to be driven such that each crest and trough are pulled on either side and rolled in order to achieve the continuous wave, however, I am struggling to find a way to simulate that, if I use FSI.
If I go the dynamic mesh route in fluent, I don't know whether a varying geometry can work, I have seen examples of valves and piston moving, but they all have fixed geometries.
I also used COMSOL, however the excitation of the plate turned out to be quite inaccurate(using a simple sine pressure load). There are other ways, for example physically applying time dependent loads across the plate and do a fsi then, but I don't really know if that's the right approach.
raynorshiene is offline   Reply With Quote
dynamic mesh, fsi 2-way coupling, travelling wave
High aspect ratio mesh problem for flat plate boundary layer sam1364 OpenFOAM 3 May 14, 2020 11:11
LES 2d on flat plate in openfoam dosen' t resolved eddis moh-farmani OpenFOAM 0 December 13, 2016 00:12
2-ways FSI problem arep_24 ANSYS 0 November 28, 2016 10:07
wave pattern problem running LTSInterFoam Alex song OpenFOAM Running, Solving & CFD 2 May 10, 2015 03:14
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
