May 14, 2012, 00:46 |
Name Selection of a surface
Alireza Safikhani
Dear friends,
My geometry is a simple spherical with a hollow in that, is there any way to select the inner surfaces with name selection tools? in fact the inner surfaces are not visible and for selecting them in the name selection is hard. Sincerely |
May 14, 2012, 01:59 |
Rep Power: 143 |
Use the selection tools in the bottom left corner of the screen to select bodies other than the one in front. Have a look at the Workbench tutorials for examples of how to use them.
May 15, 2012, 09:35 |
you can simply make a named selection and then toggle off visibility of this named selection. Then selection of inner faces will be easy.
regards |
continuum surface tension model | yukn | Main CFD Forum | 0 | October 8, 2011 06:43 |
Selection Surface for contour plot by journal file | diamondx | FLUENT | 0 | September 12, 2011 11:58 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 12:19 |
