May 19, 2012, 05:25 |
Temperature Damping
Could some one please let me know in which cases a temperature damping factor is used in CFX
Best regards, Santhosh. |
May 19, 2012, 07:08 |
Rep Power: 143 |
If you don't know what it is for then leave it at the default
The documentation will probably recommend using it for some models - I suspect combustion modelling may be helped by it, and possibly some others (but that is just a guess, you should check for yourself). |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 18:04 |
