Isolated flow regions, I think my mesh is the problem, please have a look (pics) |
June 6, 2012, 08:02 |
Max
Rep Power: 14 |
Hello all
Just as a disclaimer, I'm a complete noob at using ANSYS/CFX, so constructive criticism please! For my project I'm modelling our supersonic wind tunnel. I received a bunch of ProE parts, which I trimmed, assembled, then saved as IGES files for importing. I'm currently trying to do a test run to make sure the model works, but CFX-post is telling me that there are 5 isolated flow regions. I think the problem has to do with the way I've set the inlet/outlet, and the mesh in that region, but I'm not sure what to do. If you could look at the screenshots I've uploaded and tell me if anything immediately stands out I will love you forever. Many thanks Max |
June 6, 2012, 12:37 |
Edmund Singer P.E.
Rep Power: 20 |
Isolated regions just means that your individual volume meshes are not connected to each other.
You need to put domain interfaces between each of the mesh regions that connect to each other. |
June 6, 2012, 18:58 |
Rep Power: 143 |
Some additional comments:
* Parasolid is a better format to get geometry into Designmodeller then IGES. * Look at the Workbench tutorials on multi-body parts. This will show you some options for combining multiple bodies together. |
June 12, 2012, 15:32 |
Max
Rep Power: 14 |
Firstly, thank you both for replying, and apologies for not saying anything sooner.
I took all of your advice on board and, after redoing my model, it works! I have another issue now but I think I'll make a new post about it. |
cfx error, isolated flow region, mesh |
[GAMBIT] Gambit & 3d open channel flow mesh problem | esgee | ANSYS Meshing & Geometry | 7 | April 10, 2012 00:51 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
