June 19, 2012, 20:56 |
Bubble column - Inlet boundary conditions
OJ
Rep Power: 20 |
Hello
I was wondering what is best way to specify the inlet boundary condition for bubble columns with ring sparger. The options are:
In literature I have reviewed so far, option 1 seems mostly ( rather universally) popular, though difficult to implement in my case due to lack of availability of data. Option 2 is theoretical simplification and discards any geometrical influence and there is no evidence of this being appropriate in the literature. Option 3 seems so obvious choice, but I am yet to find a publication that mentions the use of mass flow rate at inlet. Quite surprising. Any ideas about which may be the best way? Regards OJ |
October 17, 2012, 03:49 |
bubble column
mohamad
Rep Power: 13 |
I am using inlet same condition for bubble column and with try and error I found that 0.3 is suitable for my case.can we share our information?
February 1, 2018, 20:49 |
Jie
Rep Power: 16 |
Hi OJ
I am working on some validation of bubble column simulations. against Becker 1994, 1999. I am actually using option 1 at the moment. I have a question about running a 2D case. Since there is no thickness of the bubble column, then how do you determine the inlet gas velocity in this case? The second question I have is whether it is okay to use 100% air at the inlet? Thanks |
February 2, 2018, 00:58 |
Rep Power: 143 |
What do you mean by determine the inlet gas velocity? What do you know about the case you are trying to simulate?
Whether 100% air is OK will depend on what you are trying to do and how you are modelling it.
February 4, 2018, 19:20 |
#5 | |
Jie
Rep Power: 16 |
Since I am using OpenFOAM twoPhaseEulerFoam for the calculation. If I would like to perform a 2D bubble column simulation, what is the inlet gas velocity I should impose at the inlet nozzle? Since OpenFOAM use 1 cell in the third dimension for the 2D case, the problem is whether the inlet gas velocity will be dependent on the length in third dimension, i.e. the depth of the bubble column? If it is not, then how the inlet gas velocity should be calculated for 2D bubble column? Thanks Jie |
February 4, 2018, 19:22 |
Rep Power: 143 |
Try the OpenFOAM forum. This is the CFX forum.
February 4, 2018, 19:24 |
Jie
Rep Power: 16 |
Hi Glenn
I think this a general question, which is about how to calculate the correct inlet gas velocity that should be applied at the inlet nozzel for 2D bubble column based on the experimental superficial gas velocity. Thanks Jie |
February 4, 2018, 19:28 |
Rep Power: 143 |
I do not know how OpenFOAM has handled this so I cannot say in your case. But I would have thought it very easy to just try it and find out - can't you just try a velocity and see what it does?
February 4, 2018, 19:31 |
#9 |
Jie
Rep Power: 16 |
bubble column, inlet boundary condition |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
How to set pulsating inlet boundary conditions with a very high frequency | Ton | CFX | 10 | March 22, 2012 16:57 |
Boundary conditions: inlet and outlet | aline | OpenFOAM | 7 | June 29, 2010 03:45 |
Turbulent boundary conditions for bubble column | anjai | FLUENT | 12 | October 17, 2005 06:34 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
