July 8, 2012, 09:01 |
how to solve this error ???
sina
Rep Power: 14 |
hi everybody
i am modeling multiphase flow and i counter this error: In Analysis 'Flow Analysis 1' - Domain 'fluid': The following materials require Viscosity to be defined: 'Aluminium' i try to use alminium as my dispresd solid phase and water as my countinus phase. how can i solve this error? |
July 8, 2012, 17:23 |
Hi
Danial
Rep Power: 14 |
I guess you should check your defined material's properties. If there is solid material then you should check its thermodynamic state, else chech all the materials and their thermodynamic states and you will know that there is one value missing. It is just mistake of thermodynamic state for your defined materials.
Hope it helps... |
July 9, 2012, 02:48 |
#3 | |
sina
Rep Power: 14 |
when i change solid phase to air or water this error is pass my problem is that i have one pipe and i want to have multiphase of solid-liquid in that volume of pipe but when i want to specify the volume as fluid domain i cant use directly dispresad phase as solid i try to import air instead of solid and then i change the density and other parameters but i think that this is not the right work do you have any idea to fix this problem thank |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
