Hamed Abdul Majeed
Rep Power: 14 ![]() |
Rep Power: 143 ![]() ![]() ![]() ![]() |
That looks like streamlines seeded at the inlet, with one seed per element. The mesh is biased to be finer next to the wall so the streamlines get finer next to the wall. They are coloured by velocity.
Felipe Gobbi
It's probably what Glenn said, but you should try to mess with the seeding options, there's a few of them, including a seeding line that could generate an plot similar to the one you want, at least when you look it by its side view.
What probably would change regarding the mesh refinement are the colors. As you may know, a finer mesh should give you more information about any given property hence more colors. Correct if I'm wrong! Good luck |
Hamed Abdul Majeed
Thanks guys I got much better results using the hints you gave me. Here are the results
![]() Please answer the following doubts that I have. Under sampling what do the options vertex, free edge, and face center mean?? Thank you. |
It is telling it where to sample the seed points from on your starting face.
Felipe Gobbi
I saw you PMed me, did you find the "line" (edge) I told you about?
I confused line with edge i guess! Sorry about that. I see you've got nice results! |
streamline plot |
How to plot streamline with panel method? | Fluman | Main CFD Forum | 2 | June 2, 2014 05:51 |
plot streamline | taw | Main CFD Forum | 6 | August 16, 2009 12:26 |
Streamline superimposed on velocity field | allamarein | FLUENT | 0 | July 9, 2009 20:51 |
Is it possible to plot streamline on a user surface | fkzstar | CFX | 2 | April 8, 2009 05:30 |
Streamline plot | C.Bhasker | Siemens | 12 | January 12, 2005 22:44 |
