Stuart
Rep Power: 25 ![]() |
Is it possible to view in CFD-Post where the maximum residual (as plotted by the CFD-solver during a simulation) is in a fluid domain? I've tried Isosurface, Contours, Function calculator but cannot find where to get the max residual locations. If I can where it is occuring then I can improve the mesh in that area to improve the RMS residuals and convergence - even though I'm getting a constant residual and monitor point values the RMS residual valve needs to go down by another order of magnitude. Thanks |
Lance
Rep Power: 22 ![]() |
You can get the residuals in post if you have checked the "output equation residuals" in pre (under output control). Then they will show up in the variables list in post.
Stuart
Thanks Lance.
I must have missed it in Output Control when I set up my monitor points. However, I don't see any mention of residuals in the Variables list (even expanded all the lists in Variables). Have I done something wrong or am I looking in the wrong place (even though I think I've run out of place to look)? Last edited by siw; July 26, 2012 at 06:39. Reason: Update for finished simulation |
Lance
They should be in the variables list, named something like P.Mass Residual, etc.
After the "output eqn residuals" check box, did you change "Eqn. Residuals" to "All" from "None"? If you run transient you'll need to check the "output eqn residuals" box under trn results as well to get the residuals in the trn files and not only in the .res file. |
Simon
Rep Power: 12 ![]() |
You can visualize the max. or min. residuals with a "point".
Then you can refine your mesh at this location. |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Viewing residuals | Bob Malone | CFX | 2 | February 19, 2001 08:47 |
