Mehdi Bahador
Rep Power: 14 ![]() |
Hello guys,
I did a simulation using CFX on power turbine + diffuser. I put total pressure and temperature at inlet of power turbine as inlet BC and ambient pressure as outlet BC at stuck. The BC data comes from measurements. Now I checking the the static pressure data at diffuser and unfortunetly it has some difference (about 1.5 kPa higher than test values). I did some scaling of total pressure at inlet of power turbine but It didn't help, I got wrong mass flow and wrong pressure distribution at diffuser hub and tip. I need some help of you guys on this issue. I was thinking to use a pressure scaling at interface at diffuser inlet, there is a pressure profile decay setting of interface setting, anybody knows about this setting? Thanks in advance, Mehdi534 |
Importing NACA0021 airfoil data into CFX | dougie | CFX | 2 | May 13, 2012 06:50 |
CGNS vs Tecplot Data Format | LWhitson2 | Main CFD Forum | 3 | July 1, 2011 13:50 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
How to make data file for matlab from CFX? | cfxbeginner | CFX | 4 | October 19, 2002 07:56 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
