November 20, 2012, 06:03 |
thermal conductivity expression
Thomas Hoffmann
Rep Power: 13 |
hi all.
I would like to add an expression for thermal conductivity k=-0.000837*T^2-0.030641*T+0.147212 But I get the following error: ' Bad expression value '-0.000837*T[K^2]^2-0.030641*T[K]+0.147212' detected in parameter 'Thermal Conductivity' in object '/LIBRARY/MATERIAL:Ice cream/PROPERTIES/THERMAL CONDUCTIVITY'. CEL error: Error at position 12. Units ([K^2]) are associated with a term that is not dimensionless. ' I also tried to write it like this: k=-0.000837*T[K^2]^2-0.030641*T[K]+0.147212 Does anybody know how to use the expressions in cfx? |
November 20, 2012, 06:19 |
Talita Possamai
Rep Power: 13 |
Hello Thomas,
You must indicate the units of each constant. So it should be: k=-0.000837 [W m^-1 K^-3]*T^2-0.030641 [W m^-1 K^-2]*T+0.147212 [W m^-1 K^-1] This will give you thermal conductivity in [W m^-1 K^-1] Regards, Possa |
November 20, 2012, 06:27 |
Thomas Hoffmann
Rep Power: 13 |
easy
thanks! |
December 6, 2012, 03:34 |
Thomas Hoffmann
Rep Power: 13 |
Hi Possa.
It worked for me to apply the material with this expression for thermal conductivity, but the solver has problem working with it. I tried to change all the parameters to water one by one, and found out that this expression is the only problem. Do you know if cfx nows that T is temperature? Do I have to define it somewhere? |
December 6, 2012, 04:18 |
Rep Power: 143 |
The variables and their names is listed in the CFX reference manual, under variables. You should consult it to make sure you use the correct name for variables.
December 6, 2012, 05:47 |
Talita Possamai
Rep Power: 13 |
Hello Thomas,
Yes, you're right. You must change T for Temperature for this to work. Regards, Possa |
December 7, 2012, 07:34 |
Thomas Hoffmann
Rep Power: 13 |
I had a look in the reference manual, and it says that the short variable name for temperature is 'T'. But it doesn't work for me.
Do you know where I have to define T in cfx-pre if I want to make my thermal conductivity temperature dependent? |
December 7, 2012, 07:53 |
Talita Possamai
Rep Power: 13 |
Try putting like this in the expression definition tab: -0.000837 [W m^-1 K^-3]*Temperature^2-0.030641 [W m^-1 K^-2]*Temperature+0.147212 [W m^-1 K^-1] It is Caps sensible (it will recognize Temperature but not temperature). It should work like that. Regards |
December 7, 2012, 08:00 |
#9 |
Thomas Hoffmann
Rep Power: 13 |
Great. This worked for me. Thanks!!
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
IAPWS water properties + orthotropic thermal conductivity | Chander | CFX | 1 | February 29, 2012 17:26 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
