December 11, 2012, 14:02 |
Initial Meridional Configuration Dialog
Samuel J. Hund
I am designing an axial pump using bladeGen. The dimensions have changed (Hub and shroud diameters, blade angles, etc.) Is there a way to reopen the Initial Meridional Configuration Dialog or another quick way to change these variables all at once without redoing the entire workbench. I would be satisfied with just deleting the current blade (within bladeGen and starting over). Moving the points by hand tends to crash the software since these are all large changes.
October 4, 2022, 07:43 |
KristianRanta
Rep Power: 9 |
Did you find a way to return to the meridional profile dialog and entering the main work window? Thanks.
bladegen, cfx |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
