Simulation of orifice flow meter
Old   February 12, 2013, 08:09
Default Simulation of orifice flow meter
Roland Rakos
Roland R is on a distinguished road
I tried to validate the simulation of a standard orifice flow meter. The main goal is to investigate and check the discharge coefficient. Based on the theoretical calculation and measurement, the discharge coefficient should be about 0.6 in the investigated Re number region.
http://www.engineeringtoolbox.com/or...uri-d_590.html
Based on the result of my numerical analysis, this value is 0.77. I think, this difference is high, but I don’t understand its reason. I used unsteady analysis, SST turbulence model and very fine structured hexa mesh. The y plus value is correct. I used symmetry boundaries, so a quarter tube (90 degrees) was calculated instead of the full (360 deg) model. Maybe is it the problem? Or any other thing?
Regards
Roland
Roland R is offline   Reply With Quote
Old   February 12, 2013, 08:15
Roland Rakos
...sorry, I made a mistake: the simulation is steady
Old   February 12, 2013, 09:48
Edmund Singer P.E.
singer1812 is on a distinguished road
Few things:
Are you pulling P out in same manner as a Tap would?
Did you adjust your P locations to match each of the 3 listed in that article? Does the cd vary across each of those locations? I dont think they listed which location was used for the cd that is shown (or are you using different information for your experimental data) so it has some uncertainty in it?
Did you make sure your BCs provide a fully developed flow into and eventually away from the orifice?
singer1812 is offline   Reply With Quote
Old   April 3, 2013, 08:41
Roland Rakos
Originally Posted by singer1812 View Post
Few things:
Hello Singer,
sorry for my late answer.
I dont know the details of measurements in the article. But I think that the discharge coefficient should be correct based on the geometry and the used Re number region.
Based on my university studies, the discharge coefficient should be ~0.6 in case a standard orifice flow meter. This value is higher in my simulation. I think that the separated zones are smaller in the simulation than in the reality. I would like to know its reason.
Regards
Roland
Old   April 4, 2013, 09:49
Roland Rakos
An additional question to this problem: how can be determinated the discharge coefficient from CFX result?
I determinated it based on the streamlines.
http://imageshack.us/photo/my-images/22/13826578.png/][/URL]
There is a cross section from "D geom", and a smaller one from the "D flow". Discharge coefficient has been calculated as: A flow/A geom.
What do you think about this? Is this method correct?
Regards
Roland
Comparison between Solidworks Flow Simulation and Ansys Fluent Bruce828 Main CFD Forum 5 February 23, 2013 10:13
Blockage in pipe ( using solidwork flow simulation) jchow FloEFD, FloWorks & FloTHERM 1 January 16, 2012 16:03
Amplification factors in SolidWorks Flow Simulation? george85 FloEFD, FloWorks & FloTHERM 32 September 10, 2011 20:58
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 03:49
calculate volume flow from a 2D simulation SimonH. OpenFOAM 0 October 27, 2009 04:39
