February 21, 2013, 12:07 |
flow at 15 deg. AoA over a duct - 3D case
Sandeep
hi friends ,
i am simulating flow which takes place over a duct that is protruding out of a wall . Pl find attached the picture of the flow domain and also the dimensions in 'mm' as indicated there. here are the BCs i have used : ‘Inlet’: u = 0, v = 50.83m/s, w = 200.91m/s ( as the flow is in the YZ plane at an angle of attack) ‘Outlet’ = 0 psi Top face = ‘No-slip wall’ Face 1 = ‘Opening’ at 0 psi Face 2 = ‘Opening’ at 0 psi Shaded face = ‘Symmetry’ the problem i face is that pressure which i am monitoring just upstream of the duct , where the flow hits is, comes equal to 15 psi (gauge)where as it should be around 3- 3.5 psi (g) as per calculation ? suspecting something wrong with the BCs on the Faces 1 and 2 , i have used 'opening with entrainment' , ' opening with cartesian vel. components' and also 'free slip wall' but each time the pressure has been on the higher side could you please guide me as to where i am going wrong in the AoA case , which i have tried to illustrate in the attached figure. [ for 0 deg AoA, i get good match with the analytical value.] thanks Sandeep |
February 21, 2013, 15:18 |
Edmund Singer P.E.
Rep Power: 20 |
How is this AOA? You have a wall at the top and your V velocity will just impact it.
Also, is this air? Are you running compressible? You are running this at M~0.7. |
February 21, 2013, 16:33 |
Rep Power: 143 |
This sounds like a FAQ to me: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
February 22, 2013, 06:57 |
Sandeep
@singer 1812
Fluid is 'Air ideal gas' the duct is a part of aircraft fuel system , hence the 15 deg AoA and yes the flow will impinge on the 'wall' @glenn : mostly i have tried all that the 'FAQ' tell , only afterwards i am posting this doubt here , hoping to gain from someone's experience on solving a similar problem |
February 23, 2013, 04:48 |
Rep Power: 143 |
The flow might impinge on the wall but modelling it using an inlet with a fixed AOA across the entire face is not going to be very representative. You are going to have to make the domain bigger and more representative, and allow air to spill around the side, and spall out from the impingement site - these are what really happens when a jet impinges on a wall, but your setup will not allow this to form.
February 28, 2013, 09:55 |
Sandeep
"....using an inlet with a fixed AOA across the entire face is not going to be very representative"
@glenn : 1. how to make the inlet more representative ? 2. what should i keep so as to represent the 'farfield' boundaries - which are the side and bottom faces of the box i have shown in fig. ? thanks sandeep |
February 28, 2013, 16:46 |
Rep Power: 143 |
Extend the simulation domain so you include this impingement effect. The boundary of the domain should be placed somewhere that simple flow conditions exist, like constant pressure, a simple flow in a certain direction or something like that.
You can use a pressure opening, or could use a wall. Either way do a sensitivty analysis to check it is far enough away that it is not affecting results. A Wall will need to be further away than a pressure opening. |
Secondary Flow in Square Duct | YJ Lee | Main CFD Forum | 7 | October 13, 2012 00:49 |
Turbulent Flow in Straight Square Duct - k-ep Validation | mcclud | STAR-CCM+ | 2 | August 7, 2012 16:56 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
in flow and out flow in a short duct | jane | Main CFD Forum | 0 | March 27, 2004 23:08 |
help! flow in square duct | chris | Main CFD Forum | 2 | December 22, 2003 10:13 |
