February 21, 2013, 12:31 |
Prediction of stall point
Hi everyone,
I would like to know if anyone one here knows a way to predict the stall point? For capturing stall point, I reduce the exit corrected massflow (or increase back pressure) till I get to stall. However, this method could be very time consuming, because several exit corrected mass flow rates should be tried to find the one after which stall happens. I am looking for a way to find stall point with the least number of calculations.BTW, I am working on a one stage fan. Any suggestion is appreciated. |
February 21, 2013, 16:30 |
Rep Power: 143 |
CFX predicts the flow at a given configuration. Think of it like a numerical experiment. So you are going to have to sweep over a parameter (flow rate, AOA, turbulence levels, whatever) to find the stall point.
You can speed things up by using smart curve fitting to the simulation results, for instance you can guess to some level what the stall point will be, so centre your search there. |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
matching variable data with grid point data | anfho | OpenFOAM Programming & Development | 0 | May 6, 2011 15:28 |
Plot data for a fixed point | aut_iut | OpenFOAM | 0 | December 23, 2010 05:16 |
Can't see the point, streamline and line in Post | Atit | CFX | 0 | October 28, 2004 14:53 |
static stall | atrh | Main CFD Forum | 1 | March 9, 2004 06:07 |
