how to use UDF& USER_GETVAR // what is the problem in my code |
April 7, 2013, 08:06 |
DongGunKo
Rep Power: 13 |
I coded like below
i don't know why it does not work help me #include "cfx5ext.h" dllexport(nucl) SUBROUTINE NUCL (NLOC, NRET, NARG, RET, ARGS, CRESLT, & CZ,DZ,IZ,LZ,RZ) c implicit none C C User CEL routine to calculate velocity boundary C Creates a parabolic inlet profile as function of the y coordinate C #include "MMS.h" #include "cfd_constants.h" #include "stack_point.h" C ================================================== ==================== C Arguments C ================================================== ==================== C C Result flag CHARACTER CRESLT*(*) C Number of locations in space over which calculations will be performed INTEGER NLOC C Number of CEL arguments INTEGER NARG C Number of return variables INTEGER NRET C C Argument array REAL ARGS(NLOC,NARG) C Return variable array REAL RET(NLOC,NRET) C C Stacks INTEGER IZ(*) CHARACTER CZ(*)*(1) DOUBLE PRECISION DZ(*) LOGICAL LZ(*) REAL RZ(*) C ================================================== ==================== C Local parameters C ================================================== ==================== C REAL pi, sigma, R, qc, M, k PARAMETER (pi = 3.14, sigma = 1, R = 1, qc=1, M=1, k=1) C C ================================================== ==================== C Local variables C ================================================== ==================== C INTEGER ILOC REAL dden, cden, rcri, Tc, Pc, PSAT, mcri, fraction, nucl, n, & Sheat, Lheat , a, b CHARACTER*(MXDNAM) ACTION,CGROUP,CEQN,CTERM,CPVAR, & CLVAR,CPATCH,CRESLOC,CPHASE CHARACTER*120 h2ol, h2og C------------------------------ C Stack pointers C ------------------------------ __stack_point__ Tc __stack_point__ Pc __stack_point__ PSAT __stack_point__ dden __stack_point__ cden __stack_point__ Lheat __stack_point__ a __stack_point__ b C C ================================================== ==================== C Executable statements C ================================================== ==================== C Initialise success flag. CRESLT = 'GOOD' C Initialise RET to zero. CALL SET_A_0 ( RET, NLOC*NRET ) C C---- Determine user’s phase name for use in USER_GETVAR C C Use USER_ASSEMBLE_INFO to determine solver equation and principal C variable names CEQN, CPVAR. ACTION = 'GET' CALL USER_ASSEMBLE_INFO (ACTION,CGROUP,CEQN,CTERM,CPVAR, & CLVAR,CPATCH,CRESLOC, & CZ,DZ,IZ,LZ,RZ) IF (CRESLOC.NE.'GOOD' .AND. CRESLOC.NE.'SOME') THEN CRESLT = 'FAIL' GO TO 999 ENDIF C C C C C C C C C DO ILOC = 1,NLOC fraction = ARGS(ILOC,1) c C Extract phase name from principal variable CALL GET_PHASE_FROM_VAR (CPVAR, CPHASE) C Convert solver phase name to user phase name. CALL CONVERT_NAME_S2U('Phase',CPHASE,' ',h2og, & CRESLT, CZ,DZ,IZ,LZ,RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2og.Saturation Pressure', CRESLT, & PSAT, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2og.Pressure', CRESLT, & Pc, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2og.Temperature', CRESLT, & Tc, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2og.Density', CRESLT, & cden, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c c c CALL CONVERT_NAME_S2U('Phase',CPHASE,' ',h2ol, & CRESLT, CZ,DZ,IZ,LZ,RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2ol.Density', CRESLT, & dden, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c c call USER_GETVAR ('h2ol.Latent Heat', CRESLT, & Lheat, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2ol.Specific Heat Capacity at Constant & Volume', CRESLT, a, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c call USER_GETVAR ('h2ol.Specific Heat Capacity at Constant & Pressure', CRESLT, b, CZ, DZ, IZ, LZ, RZ) IF (CRESLT .NE. 'GOOD') GO TO 999 c Sheat=a/b C C c c c c c rcri = (2*sigma)/(R*Tc*dden*CLOG(Pc/PSAT)) mcri=(4/3)*pi*dden*(rcri**3) n=((sheat-1)/(sheat+1))*(Lheat/(R*Tc))*((Lheat/(R*Tc))-(1/2)) c nucl= (qc/(1+n))*SQRT((2*sigma)/(pi*M))* & ((cden**2)/dden)*EXP((-4*pi*sigma*(rcri**2))/(3*k*Tc)) RET(ILOC,1) = mcri*fraction*nucl END DO C C Set success flag. CRESLT = 'GOOD' C 999 CONTINUE END |
April 7, 2013, 18:00 |
Rep Power: 143 |
Nobody on this forum has time to debug your code from scratch.
Post the error message you are getting, or something to suggest why it is not working. "i don't know why it does not work" is not a very useful description of the failure. |
April 8, 2013, 00:16 |
sorry
DongGunKo
Rep Power: 13 |
i don' know how to use this page.
i will change question |
udf, udf and programming, user_getvar |
COBRAS code | novan tofany | Main CFD Forum | 0 | October 8, 2012 04:40 |
Problem in k-eps turbulence code in complex geometry | sontukaku | Main CFD Forum | 2 | December 28, 2010 00:44 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
own Code vs. commercial code | Bernhard Mueck | Main CFD Forum | 10 | February 16, 2000 10:07 |
