Grid dependency study in building heat transfer |
April 10, 2013, 13:20 |
sunil
Rep Power: 13 |
Hello sir,
I am doing my M Tech Project on building heat transfer.i have considered single room of dimensions 4*4*4 m.i am applying heat flux to the walls heat flux is varying with time.i have to run my simulation for 24 hours(Total time = 86400 s) my question is for grid dependency study either i have to very both time step size and grid size(space and time) or any one of them is enough because it takes too much of computational time even for time step of 10 s to solve for given total time Results which i am interested are 1.Average room temperature 2.avg wall temperature Thank you sir |
April 10, 2013, 16:17 |
#2 | |
Dmitry
Rep Power: 14 |
user54862_pic391_1340124620.jpg |
April 10, 2013, 21:00 |
Rep Power: 143 |
This is why I strongly recommend using adaptive timestepping. Set adaptive time stepping to home in on 3-5 coeff loops per iteration, then yoru timestep is automatically calculated and you have one less variable to do a sensitivity analysis on.
April 11, 2013, 02:10 |
Grid dependency
sunil
Rep Power: 13 |
Hello sir,
Thank you for reply. i will try to run solver with adaptive time stepping as you suggested Thank you sir Sunil Patil |
April 11, 2013, 09:26 |
#5 | |
Mr CFD
Rep Power: 14 |
Where did you get the presentation from? What's the title of the presentation? Thanks |
building heat transfer, grid dependency, transient analysis |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
heat transfer prediction. | ranjeet | Main CFD Forum | 6 | September 1, 1999 06:41 |
