April 24, 2013, 12:33 |
Natural convection
hi everyone
ı am studying natural convection in a closed room. Room is heated below and cooled by window. But solition is not converged. Can you help me in this problem? steady-state turbulance model: Realizable k-epsilon model matterrial of fluid : air boussinesq Solution methods :Green-gausse node based, pressureresto the other parameters are second order upwind solition controls: momentum 0.7, others are default |
April 25, 2013, 07:17 |
Rep Power: 143 |
This looks like Fluent settings. Try the Fluent forum.
April 25, 2013, 08:56 |
Erik
Rep Power: 23 |
3D buoyant flows often have no steady state solution, hence will never converge using steady state solver. You can only converge your imbalances or wait until the variable you care about is steady.
April 25, 2013, 09:42 |
OJ
Rep Power: 20 |
Seems you are using Boussinesq's model for gravity in buoyant flow. You should be careful here since this model is valid only for small differences in the temperature throughout the domain, which allow the definition of density as a function of temperature and expansion coefficient. The definition will collapse in the presence of higher temperature gradients.
OJ |
October 13, 2013, 07:54 |
Ashutosh
Rep Power: 12 |
Please can you be more specific as to what temperature range can we allow for buoyant flows? Also if my temperature range exceeds this one how should I model the flow..
October 13, 2013, 17:09 |
Rep Power: 143 |
That depends on how accurate you want to be. The alternative is to use a more complete constitutive model such as ideal gas or real gas.
October 14, 2013, 07:11 |
OJ
Rep Power: 20 |
Boussinesq's model prescribes the density as a function of thermal expansion coefficient and the difference between local temperature and operating temperature , and density at operating temperature .
The Boussinesq assumption is valid only when Otherwise you have fairly large temperature differences and you need to comprehensively model density as a function of temperature/pressure as Glenn mentioned OJ |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural Convection Problem - Helium | marzoa | STAR-CCM+ | 0 | April 18, 2011 14:12 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection in a sealed enclosure | James | Main CFD Forum | 4 | April 2, 2001 15:48 |
