April 26, 2013, 07:16 |
What does this message mean?
Prashant Kumar Singh
Dear All
I am doing inflow distortion analysis in CFX for single stage axial flow fan. While running following is showing in between iteration, what is its significance? ****** Notice ****** | | A wall has been placed at portion(s) of an INLET | | boundary condition (at 6.9% of the faces, 4.3% of the area) | | to prevent fluid from flowing out of the domain. | | The boundary condition name is: Inlet. | | The fluid name is: Air Ideal Gas. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | thanks +--------------------------------------------- |
April 26, 2013, 07:21 |
Rep Power: 143 |
It means exactly what it says: you have back flow at your inlet which the solver artificially stopped. This is sometimes not a problem, but often it is and it certainly makes convergence harder. Move your inlets further upstream to get it out of the recirculation.
April 26, 2013, 09:58 |
Thanks Sir,
Yes I am getting problem in convergence. Can i say that back flow at the inlet may be due to compressor stall or surge? |
April 27, 2013, 06:50 |
Rep Power: 143 |
There is an FAQ on this as well (the concept is just as applicable to inlets as outlets).
No, this is unlikely to be related to stall or surge. Don't forget an inlet is upstream of the rotor . |
ShockTube, error message. | foamer | OpenFOAM | 8 | January 30, 2013 04:31 |
single directional message transmit in parallel model | su_junwei | OpenFOAM Programming & Development | 1 | December 17, 2009 07:00 |
Error message in CFX-10 | CFDworker | CFX | 2 | October 12, 2007 07:23 |
how to avoid reverse flow message | Amit Mahulkar | FLUENT | 0 | April 20, 2006 00:45 |
Error Message on es-ice [BUG] | Wendy Tjia | Siemens | 0 | February 10, 2005 08:40 |
