May 21, 2013, 08:52 |
ICEM CFD - Remeshing - Basic
Rep Power: 13 |
I have a problem to get the remeshing starting. I'm actually testing the well known "ANSYS Tutorial: CFX Re-Meshing" tutorial: http://www.edr.no/blogg/ansys_blogge...cfx_re_meshing I have allready checked my settings twice but I can't find the reason for the following behaviour: The solver stops when the interrupt condition is "reached" but then no remeshing occurs - the solver finished. In CFD-Post I can see the box moving until the stop. So, what could be the reason for that? I'm deeply grateful for help. |
May 22, 2013, 07:27 |
OJ
Rep Power: 20 |
June 20, 2013, 09:53 |
Vipul
Rep Power: 13 |
Hi Bill,
I'm having similar problems as well. CFX executes the interruption routine but then doesn't carry out the remeshing. Have you found a solution for this yet? Thanks for your help. |
June 21, 2013, 04:11 |
Rep Power: 13 |
Hi vplpaul,
***yes, but it was related to my PC setup - not to my experimental setup. If you use Windows: Try to remove the ICEM path variabel from your windows environment variabels - it was somethink like ICEM_ROOT or ICEM_CFD_ROOT or just ICEM_CFD (I don't know the exact name, anymore).*** Sorry, this was the reason of another problem. The "non starting remeshing" problem occured when I used the "Essential" and "Low Speed Most Compression" options in the output control. I switched it to the Default settings and everything worked. But I don't know the exact crucial part ("Results", "Trn Results", ...)... I hope this will help you, too. Last edited by Bill Tuer; June 22, 2013 at 08:27. Reason: Confusion |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
Learn ANSYS ICEM CFD | easy_astronaut | ANSYS | 2 | December 15, 2013 15:34 |
[ANSYS Meshing] Issues in exporting mesh from Meshing to ICEM CFD | sihaqqi | ANSYS Meshing & Geometry | 5 | March 5, 2013 02:40 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
