May 26, 2013, 14:04 |
how to constrain rigid body motion
Mohamad Alagheband
Hi
Does anybody know how I can constrain a rigid body motion I mean for like specific rotational angle ? I can not just stop the solution and re-run for fixed boundaries because my inlet velocity profile is pulsatile. thanks |
May 26, 2013, 21:34 |
Ma.L
when you define a rigidbody,you can define the degree of freedom of it,including Movement and Rotation。
good luck。 |
May 27, 2013, 05:32 |
#3 | |
Mohamad Alagheband
thanks for reply I knew what you mentioned but i am trying to constrain rotation angle i mean when RB rotated for certain angles then it should be stopped in that position and solution go on with fixed boundaries and i don't know how much time does it take to rotate and i am going to find out by RB simulation? Tnx |
May 27, 2013, 08:17 |
Matthias Voß
Rep Power: 20 |
hey
not sure if i got you right, but if you can express your RBmovement via CCL then you can simply add another expression with respect to simulation "runtime counters" like AITERN,CITERN,T,TSTEP or ATSTEP. e.g. Code:
RampLength = 1.0[s] Ramp = (-2*(min((t)/RampLength,1))^3+3*(min((t)/RampLength,1))^2) |
May 28, 2013, 09:56 |
Matthias Voß
Rep Power: 20 |
some thoughts:
1# you can apply a symmetry on the middle ?! 2# never done smth. with RBM but maybe you can use this as a starting point Code:
New X = ((x-X0)-Total Mesh Displacement X)*cos(alpha)+((y-Y0)-Total Mesh Displacement Y)*sin(alpha)+X0 New Y = -((x-X0)-Total Mesh Displacement X)*sin(alpha)+((y-Y0)-Total Mesh Displacement Y)*cos(alpha)+Y0 New Z = ((z-Z0)-Total Mesh Displacement Z) + Z0 X0 = 0 [mm] Y0 = 0 [mm] Z0 = 0[mm] 3# your are running transient cases, right? |
May 28, 2013, 10:58 |
Mohamad Alagheband
Dear Matthias
I am really appreciate for spending time to answer. As you said I am running a transient simulation with symmetric geometry and my biggest problem is finding rotation angle . I know the range of rotation but i do not know exact value for rotation angle and i am trying to find out by RBM (i mean applying momentum forces to RB) and i think that code must work for known rotation angle |
May 28, 2013, 11:09 |
Matthias Voß
Rep Power: 20 |
u r welcome.
You apply the forces on the RB (input) and you are interested in the transient behavior and end position(output) of the RB in equilibrium state when also applying the given inlet conditions?! So to get the real position is totally a topic for post-processing. Is that correct? First guess--- define a Monitor point at a certain node of the RB and grab the coordinates. |
May 28, 2013, 13:18 |
#9 | |
Mohamad Alagheband
this is my problem the leaflet must stop at 85 degree and simulation go on until the end of the pulse thank you a lot Last edited by MUMMED; May 28, 2013 at 15:26. |
May 28, 2013, 15:12 |
Edmund Singer P.E.
Rep Power: 20 |
If you are using the 6DOF solver, as implemented in CFX, you cant constrain a rigid body to rotate about a hingepoint (not coincedent with the body center).
That said, this is easy enough to do with the CEL equations that newbie has layed out (I didnt check for correctness). You can use CEL to limit alpha to what you want, and you can use equations of motion to put d(alpha)/dt in terms of forces (moments), which you can read off the body. Note (X0,Y0,Z0) will be your hinge point. |
May 28, 2013, 15:37 |
#11 | |
Mohamad Alagheband
up to now I have been working with 6DOF solver and I do not have much experience to apply momentum with CEL. Do you have any suggestion? thanks |
May 28, 2013, 16:39 |
#12 |
Edmund Singer P.E.
Rep Power: 20 |
Are you familiar with CEL?
Can you discretize angular motion equations? If the answer to both of those is no, I would start with reading up on the CEL section of CFX help docs. Then read up on angular motion in a dynamics book. A complete discussion is more than I want to put in this forum. Specific questions on either of those topics (other than how do i do the entire thing) I can answer. |
May 29, 2013, 02:49 |
#13 |
Mohamad Alagheband
you are right
I read CEL section and angular momentum before and I should take a look again I would like to thank you again for spending time. Thanks |
April 13, 2020, 13:47 |
#14 | |
John Applesmith
Rep Power: 6 |
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 01:40 |
CEL code for simulating the equation of motion of a vibrating rigid body | mohamadaliv | CFX | 11 | October 19, 2011 04:30 |
Using solidBodyMotion for rigid body motion | L1011 | OpenFOAM | 4 | July 5, 2011 04:59 |
rigid body motion | antonello | FLUENT | 3 | July 28, 2004 03:25 |
