May 27, 2013, 08:31 |
setting Timestep
Francesco
Rep Power: 14 |
Hi everybody,
I'm running a steady simulation of a centrifugal blower. Usually I do the following: 1. I set a really small timestep order to E-06 with Upwind scheme; 2. after 1000 iterations I switch timestep to E-05 with upwind scheme; 3. when physical properties which I monitor are stable, I switch to Blend Factor =0.75 (so not completely High resolution) and wait for a new stable state. This process usually works, but not now. Until I use upwind solution seems reach the convergence, but when I switch to Blend factor 0.75 ( i tried 0.6 as well) it doesn't happen. I changed a lot of timestep between E-5 and E-7, but seems no works. Someone has an idea about this behaviour and about what I should do? Thanks |
May 27, 2013, 18:50 |
Rep Power: 143 |
This is typical behaviour when you switch to a more accurate discretisation scheme. It means your simulation is not very numerically stable. In your case this probably means you need better mesh quality.
May 28, 2013, 03:08 |
Francesco
Rep Power: 14 |
I'll do a new mesh.
Thanks man. U precious! |
cfx, convergence, convergence problem, timestep |
Residual level setting of Fluent | lhlh | ANSYS | 2 | November 17, 2012 21:35 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
LiftDrag utility from v12 to v141 | cfdphil | OpenFOAM Running, Solving & CFD | 2 | December 5, 2007 05:49 |
Ultra high temperature? | bk | Siemens | 2 | July 19, 2005 00:01 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
