June 8, 2013, 21:38 |
CFX - .RES to NISA
Dear All
I am testing some of my adaptive meshing algos using coupling between ANSYS Mechanical - CFX solver in Workbench. For this purpose I need to get an output NISA mesh file (Fluid) to apply my routines. It seems the CFX solver essentially outputs a compiled resource script which can be taken as an input by CFD-Post. Kindly let me know if there is anyway to get the mesh position data in any of the standard formats. Thanks in advance. |
June 10, 2013, 22:36 |
Rep Power: 143 |
You will probably have to do a user fortran routine in CFX to output your mesh and read in the updated mesh.
June 10, 2013, 23:26 |
Thanks. So the .CRS format shows final deformed configuration in CFD-Post but when I output a mesh in NISA format in Finite Element Modeler it outputs the initial undeformed mesh.
cfx ansys fsi, mesh conversion |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
