Rotating and stationary walls
Old   June 13, 2013, 11:14
Default Rotating and stationary walls
Martijn Al
martijnal is on a distinguished road
Hi all,
I'm new to Ansys CFX and this is my first post so my apologies if this is in the wrong section or the question is too easy
I made a schematic drawing here: https://www.dropbox.com/s/czpkzrjoca...%20element.png
Black are the stationary wall's, red is a rotating wall (the outside of a rotating filter element in real life), green the outlet en yellow the inlet.
The internal volume I modeled with Solidworks and imported into Ansys Workbench. Creating a mesh I used all standard values and created some 'named sections'.
Then in the CFX-Pre window, I think I need to create 2 domains: 1 that is stationary and had the inlet and the black walls and the 2nd one that has the outlet and the red rotating walls. (Am I still correct?)
Now, when I make my first domain I chose as location B41 (or Assembly, but this is the same), but this is the total model. For the second domain I thus cannot select another location since "The same location has been specified for more than one domain."
Can anyone please tell me how I am able to 'split' my assembly so I can make 2 domains? And should that be done in the Geometry, mesh or setup window in Workbench?
I tried to find a CFX tutorial with multiple domains but all files were already meshed so I have no idea how this 'split' was done.
Kind Regard,
Martijn
martijnal is offline   Reply With Quote
Old   June 13, 2013, 12:48
Erik
evcelica is on a distinguished road
It looks to me that you only have 1 domain. A domain would be a 3D volume. Your walls are boundaries, not domains. So in CFX-Pre you would insert boundary, apply it to the moving walls, and define the wall velocity.
evcelica is offline   Reply With Quote
Old   June 14, 2013, 03:32
Martijn Al
I found it. Thank you
Old   October 16, 2016, 06:05
Default CFD Anlysis of centrifugal pump
K.Singh is on a distinguished road
Hi everyone,
I am doing CFD analysis of centrifugal pumps using Ansys having volute as stationary part and impeller as rotating part. For meshing I m using ansys meshing but i don't know how to create interface between impeller and volute.
Please help
K.Singh is offline   Reply With Quote
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 11:16
Rotating Pipe inside a stationary pipe Richy STAR-CCM+ 3 February 7, 2013 04:10
Viewing Rotating and Stationary Domains in Post tango711 CFX 1 August 23, 2012 08:09
[ICEM] Meshing Simple rotating domain in a External stationary domain sreenivas ANSYS Meshing & Geometry 0 January 26, 2012 22:57
rotating propeller in stationary baffled vessel wlt_1985 FLUENT 27 March 30, 2011 01:22
