setup outlet boundary condition from steady state result |
July 17, 2013, 11:20 |
Shashwat
Rep Power: 14 |
Dear all
In my steady state analysis inlet is pressure (specified value) and outlet is velocity ( known value). later I want to run transient analysis. In this case, I would like to use the outlet as a pressure which is derived from the result of steady state at the outlet . please help me How to setup this condition? Thank you |
July 17, 2013, 18:42 |
Rep Power: 143 |
This is simple - just define the outlet as a pressure boundary and give it the pressure value from your steady state analysis. When you run the transient simulation use the steady state run as an initial condition.
July 23, 2013, 03:53 |
#3 | |
Govindaraju
Rep Power: 17 |
I set inlet with velocity as a function of time and I set the outlet boundary condition as areaAve(Pressure)@outlet. I need to clarify the following basic questions. 1. Is it correct setting ?( I dont' know the pressure value at the outlet. note that I set initial velocity and pressure when t=0) 2. In my setting, is the areaAve(Pressure)@outlet means free pressure boundary condition? Thank you |
July 23, 2013, 06:04 |
Rep Power: 143 |
Do not specify the outlet as areaAve(Pressure)@Outlet! That is not going to work. You need to set it to a pressure value, probably just 0Pa.
What is a free pressure boundary condition? You have to set either the pressure or the velocity, and the other one is solved by the software. |
July 23, 2013, 09:01 |
#5 | |
Govindaraju
Rep Power: 17 |
just define the outlet as a pressure boundary and give it the pressure value from your steady state analysis can you please give one example I could not understand. How I can give the pressure value when the solution finishes steady state and start transient automatically? ( I may setup steady state and transient through configuration control ) Thank you |
July 23, 2013, 16:49 |
Rep Power: 143 |
This is in effect setting the outlet pressure to the average it was last iteration. I have no idea what this is going to do, but I suspect you will have problems converging.
Have a look at the tutorial examples of how outlet boundaries are meant to be defined. |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Outlet boundary condition | colen | CFX | 6 | March 8, 2010 22:49 |
