July 19, 2013, 11:25 |
single heavy oil droplet
Disabled
Rep Power: 13 |
Hello everyone
I work on the combustion of a drop of heavy oil falling (single heavy oïl droplet). I use JetA Lequid on CFX, but I would define a drop of about 3mm diameter entering periodically in a combustion chamber with a given frequency (several times per minute). How to define the injection mode I want to have in CFX-Pre? Thank you for anyone who could help me. |
July 19, 2013, 18:20 |
Rep Power: 143 |
You need to make a few decisions before your question can be answered.
How are you going to model this? There are several approaches and they are all very different: 1) Directly model the droplet with a free surface model. This can model the exact physics of the drop at a microscopic level, but means you will not be able to model much more than a single drop. 2) Model a cloud of drops with a eularian model. This is probably not a good approach if the aim is to track and burn droplets. 3) Model the droplets with a lagrangian particle tracking model. Then the droplet and its state is represented by a few key parameters (temperature, composition, size, density etc). You then need a model of the droplet drag, combustion and anything else you plan on modelling. |
July 19, 2013, 22:15 |
Disabled
Rep Power: 13 |
Hello and thank you for your reply.
For the evaporation model that seems appropriate is the easiest. What interests me is what is combustion with Eddy Dissipation model. My combustion chamber is a rectangle of 5 m depth where I inject several times a minute (about 50 times / min) a drop of oil of about 3mm, and there is an air inlet at about 900 ° C . Theoretically, during the fall, the drop will evaporate and oil vapor mixed with air at a rate of 0.232 Oxygen burns and releases heat flux. The exact physics of gout does not seem necessary to me. On pre-Cfx, using the library oil_combustion.ccl I can not set the injection conditions I want. If you have any idea thank you for giving me advice. sincerely |
July 20, 2013, 06:11 |
Rep Power: 143 |
You have not answered the question - but I take it from your answer you think the lagrangian particle tracking approach is best.
Your initial post suggests you do not know how to start the droplets - have a look at the tutorials to explain this. Your second post suggests you cannot set the injection conditions you want but you have not explained what injection conditions you are trying to achieve. |
single droplet - dieselFoam | mystix | OpenFOAM | 0 | September 2, 2010 06:55 |
how to simulate single droplet transcient evaporation using fluent6.3 | Dhb | FLUENT | 0 | May 15, 2009 09:28 |
Boundary Condition for single droplet evaporation | Deepak Kumar Mandal | Siemens | 0 | January 30, 2007 09:25 |
heavy fuel oil combustion | imet | FLUENT | 0 | April 11, 2005 03:57 |
single liquid fuel droplet combustion(unbounded) | Dipankar Chatterjee | FLUENT | 0 | March 18, 2002 06:35 |
