August 2, 2013, 15:00 |
CFD of Wing on fixed Angle of Attack
SAMUEL CARLOS
Rep Power: 13 |
Hi guys I would like do make a CFD to evaluate the lift on a Wing of a little airplane ( the area of this wing is around 1 m^2). But I need to make the analyses on AOA =4.5 deg this is my problem!
I'm using CFX and I've Already created the enclosure around the Wing and the mesh too. I've used expressions on CFX to define AOA and the initial velocity (actually the velocity is a constant). And I've defined Ux e Uy the velocity o axis X and Y Ux = velocityXcos(AOA) Uy =velocityXsin(AOA) but every time that I put this program to run something wrong happened. and the simulations is stopped someone have an idea? let me know it Please I need help!!! |
August 2, 2013, 22:13 |
SAMUEL CARLOS
Rep Power: 13 |
August 3, 2013, 00:11 |
DB
Rep Power: 15 |
I think something is wrong in the boundary conditions or initialization.
-D.B |
August 3, 2013, 03:04 |
CFX gives you information on grid quality. Angle should be >18 and two more parameters.
1. check these quality metrics for mesh. 2. Check scaling of domain. In other words, if you have have made the geometry in mm, again you must have same units after importing mesh to CFX Pre. 3. Boundary conditions. Check them carefully. Especially while defining the angle of attack. 4. Are you using auto time scale? |
August 3, 2013, 09:48 |
#6 | |
SAMUEL CARLOS
Rep Power: 13 |
Yes I'm using auto time scale, I couldan't? Boundary conditions I´ve difined Inlet as u = Ux V = Uy W = 0 Outlet = 0 Pa and the other surfaces including de surface of the wing as Wall. |
August 3, 2013, 09:51 |
SAMUEL CARLOS
Rep Power: 13 |
Another informations guys when I use just one velocity in Inlet boundary as 20m/s the simulations no problem!!!
Someone have a tutorial for me ? |
August 4, 2013, 07:09 |
Rep Power: 143 |
CFX comes with tutorials, the ANSYS Customer page has more and CFX support has even more examples.
CFX convergence problem simulating ogive-cylinders at varied angle of attack | jdacosta | CFX | 6 | February 25, 2015 21:42 |
Delta wing cfd | H_R | FLUENT | 16 | September 19, 2013 04:41 |
CFD of flapping wing mav | sultan | Main CFD Forum | 12 | February 28, 2013 19:01 |
I want to find overall solution about wing cfd | moons2001 | FLUENT | 0 | August 27, 2009 01:12 |
angle of attack with icem hexa | icem beginner | Main CFD Forum | 0 | December 5, 2008 16:54 |
