August 21, 2013, 13:24 |
Conjugate Heat Transfer
I'm attempting to model an aluminum engine cylinder to determine the cooling effect of airflow over the cylinder. The model consisted of a hollow cylinder, capped at one end, with a series of cooling fins along its length. I first ran a CHT with no airflow. The heat transfer coefficient of 200 W m^-2 K^-1 was applied to the outside surfaces. A wall was established on the inside diameter with 300 deg. F applied.
A second model was constructed with the same geometry but with air flowing over the cylinder. The domain interface between the solid aluminum and air (fluid) was set to Conservative Interface Flux. An inflation layer was included when meshing the fluid. Inlet velocity was set to 5 knots and an SST turbulence model was employed. When comparing the models, the analysis with air flow is reporting hotter temperatures than the one without air flow. What am I missing? |
August 21, 2013, 16:24 |
Alex
Rep Power: 47 |
You are not necessarily missing anything.
Since you have a fixed temperature boundary condition to add heat in both cases, the maximum temperature should be the same. But since you have a fixed heat transfer coefficient to remove the heat in the first case, whereas in the second case the heat transfer coefficient is a result of the fluid flow around the cylinder, the temperature distributions will be different. |
August 21, 2013, 18:36 |
Rep Power: 143 |
And also be careful about convergence on CHT models. Your solid only model should be fine, but you need to be extra careful with convergence on CHT models. The best way to ensure convergence in CHT models is to include imbalances in your convergence critereon.
August 22, 2013, 07:47 |
Thanks for the replies.
What do you mean by "include imbalances in your convergence critereon"? How do I do that? (Sorry - I'm new to CFD ) |
August 22, 2013, 19:23 |
Rep Power: 143 |
In CFX-Pre: Solver Control/Convergence Criteria, Turn "Conservation Target" on. The tolerance is 1% by default, do a sensitivity analysis on this number to get the accuracy you need.
August 23, 2013, 07:20 |
Thanks for your help!
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
