Axial Turbine
Old   September 13, 2013, 00:54
Default Axial Turbine
Rameez
rameezib is on a distinguished road
We are trying to simulate an assembly of axial turbine which consists of upstream guide vane followed by a rotor followed by a downstream guide vane. We were providing the inlet boundary conditions at the inlet of upstream guide vane and outlet at downstream guide vane. Our results are not up to the mark.
We have a query, instead of providing the outlet boundary conditions to the outlet of downstream guide vane, can we provide it at the exit of the rotor stage? If so, how do we do it.
Thanks.
rameezib is offline   Reply With Quote
Old   September 16, 2013, 07:46
D.B
DB
D.B is on a distinguished road
You will have to remove the EGV's for that. U can't have a BC in middle of ur domain, ( hence BOUNDARY condition :P )
There might be more than one reason for ur mismatch of results, Simplifying the geometry might or might not help.
-D.B
D.B is offline   Reply With Quote
axial turbine, boundary conditions
Axial Flow Turbine Problem Manish FLUENT 1 February 14, 2017 03:46
Sliding mesh vs MRF in axial turbine simulation Vito FLUENT 3 December 21, 2011 04:57
Axial Thrust in a Radial Turbine Amit Roghs CFX 3 May 31, 2010 16:47
simulation Axial flow turbine using CFX dia aisa CFX 3 May 2, 2008 02:45
