October 29, 2013, 03:57 |
multiphase
santosh kumar
Rep Power: 12 |
i want to try a problem which have one pipe which is connected with two other pipes. in the main pipe nitrogen and argon liquid is flowing and in the branch pipes nitrogen gas is flowing. I want to the simulation for heat and mass transfer analysis as well as the track the nitrogen bubbles.
so please suggest me which model i try in CFX for the above type problem Is multiphase and multi-component model coupling possible in CFX? then how? |
October 29, 2013, 05:03 |
Rep Power: 143 |
This sounds like a multi-phase and multi-component simulation as you suggest. Yes, this is possible in CFX. The CFX tutorials cover the basics of multiphase and multicomponent simulations so that is the place to start.
November 1, 2013, 03:39 |
santosh kumar
Rep Power: 12 |
what are the major draw back of CFX compare to fluent for the multi phase and multi-component problems.
which have better converging criteria |
November 1, 2013, 04:22 |
Rep Power: 143 |
Try them both and work it out for yourself. They both have advantages and disadvantages.
Multiphase and Non Newtonian fluid | wanna88 | FLUENT | 0 | May 27, 2013 00:09 |
Immersion Multiphase Heat Transfer | Liquid774 | FLUENT | 0 | June 4, 2012 15:37 |
Use data from multiphase into DO radiation | yashmash | FLUENT | 0 | October 7, 2011 03:57 |
multiphase multicomponent physics | ckleanth | CFX | 3 | June 4, 2009 20:15 |
Multiphase flow modeling | Paul | CFX | 2 | August 11, 2003 09:41 |
