November 25, 2013, 04:37 |
calculating time residence in an axial pump
Mohamad Alagheband
I'm trying to calculate time residence of blood in an axial blood pump and I have no idea how to do it. Thanks for any advice. |
November 25, 2013, 09:48 |
Edmund Singer P.E.
Rep Power: 20 |
Steady State Solution?
Short answer: -Create a new varible i.e. rtime [s] -Create subdomain of your whole domain and set a constant source term for rtime in that subdomain -Set rtime = 0 at your inlet -Run solution solving for this variable (you can freeze your old solution and just run solving for this variable if you already have a result). For more details - Look up "Age of Air" in the search |
November 25, 2013, 10:08 |
#3 | |
Mohamad Alagheband
Thank you a lot, that was very helpful . |
November 25, 2013, 16:06 |
Rep Power: 143 |
For steady state simulations you can also do this using a streamline. This has the advantage that it is just post-processing, you do not need to do a new simulation.
Put a streamline on your domain starting from the time=0 point. On the color tab of the streamline select mode=time. That's all, very simple. |
November 26, 2013, 04:10 |
Mohamad Alagheband
thanks Glenn
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
Calculating time | thuy | FLUENT | 5 | April 10, 2008 04:23 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
