December 3, 2013, 15:15 |
Force Function Calculator Ansys CFD Post
Sharad
Rep Power: 12 |
Hi guys,
My question is very basic. I read through the Ansys 14.5 manuals but it doesn't seem to answer my question so posting on here! I have a lorry model sat in a wind tunnel setup (Drawn on XY plane and extruded through Z axis). Now when I need to find the Drag Force on this lorry, I click on Function Calculator in CFD post and select the Z component for direction and it displays a force. My question is How does Ansys calculate this force? Does it use the generic Drag Equation = 0.5*rho*Usquared*Area? And if so what Area is it using? Is it all of the surface area of the lorry or just the cross sectional frontal area? Thanks in Advance! |
December 3, 2013, 17:03 |
Rep Power: 143 |
No, it is not using drag=0.5*rho*A*U^2
It is integrating the pressure and wall shear over the surface of the body. |
December 3, 2013, 17:21 |
Sharad
Rep Power: 12 |
Ah I'm guessing that equation originally comes from Navier stokes equations then. Will need to read into that stuff.
Forgot to mention that I have applied an inflation layer on the lorry. I calculated the boundary layer thickness and applied it as the inflation layer. But I'm guessing that with or without these layers that is how Ansys will always solve it? Thanks for the help!! |
December 3, 2013, 17:31 |
Rep Power: 143 |
Regardless of how you have meshed it it integrates over the surface. The meshing will "just" determine the accuracy of the simulation, not the approach.
December 3, 2013, 17:35 |
Sharad
Rep Power: 12 |
Thanks ever so much. Has made it clearer now!
January 30, 2014, 03:10 |
I want find drag force and force of water axial turbine
Natthawut
I want know value drag force and force at water turbine blade
The water axial turbine have eigth blade. I use Calculate Function in CFD Post (Ansys 13) result force in Program is much greater than the experimental result. Thank a lot, Natthawut |
January 30, 2014, 03:51 |
Rep Power: 143 |
August 14, 2014, 03:44 |
Cedric
Rep Power: 11 |
Hello World,
if i calculate the force in any direction, is the answer the sum of pressure force and wall shear or only one of the components? |
August 14, 2014, 03:50 |
Cedric
Rep Power: 11 |
i thin k i found the Answer by myself:
The force on a boundary is calculated using momentum flow data from the results file, if it is available. The result can be positive or negative, indicating the direction of the force. For non-boundary locators, an approximate force is always calculated. CFD-Post calculates the approximate force as follows:
April 19, 2016, 11:00 |
alex
Rep Power: 10 |
so if i am getting negative value for drag instead of getting positive value. it means that my wing has stalled.
April 19, 2016, 18:33 |
#11 |
Rep Power: 143 |
A stalled wing should produce lots of drag.
Negative drag means your simulation is inaccurate. There is a small possibly you are doing a strange case when the really drag is negative, such as accelerating airfoils, rapid pitch changes or something like that. But then the negative drag is just a temporary thing. |
April 20, 2016, 01:37 |
#12 |
alex
Rep Power: 10 |
well i am getting positive value for my lower angle of attack and at higher angle of attack say 9 deg i am getting negative drag value.
April 20, 2016, 03:34 |
#13 |
Rep Power: 143 |
So my previous post went on to say "Negative drag means your simulation is inaccurate". So you need to do the normal checks and sensitivity analyses to get an accurate result.
Please post an image of what you are modelling, your output file and how you are working out the drag. |
April 20, 2016, 04:35 |
#14 |
alex
Rep Power: 10 |
April 20, 2016, 05:51 |
#15 |
alex
Rep Power: 10 |
i set my convergence criteria ie 10e-5.
April 20, 2016, 06:00 |
#16 |
Rep Power: 143 |
Your images are too small to be useful. Please attach the full resolution images. Also:
* Describe what the images are showing * Attach your output file. |
April 20, 2016, 07:32 |
#17 |
alex
Rep Power: 10 |
April 22, 2016, 14:21 |
#18 |
alex
Rep Power: 10 |
now I realized that my meshing is wrong that i have to change it. Any ideas how to do it and to do stability analysis, verification and validation. I dont people to guide me that's why i am asking lot of doubt. so please dont think that i am troubling u guys. thanks a ton for help so far and i hope u provide it continously.
April 23, 2016, 07:16 |
#19 |
Rep Power: 143 |
Assuming your foil is moving at a reasonable Re number (1e5 or higher), then your mesh is too coarse and you have no inflation layers. You will need inflation layer for good boundary layer resolution and I am sure a mesh size sensitivity study will show your mesh is too coarse.
As for stability analysis, verification and validation - these are complex topics and I cannot describe them in a forum post. Do some background reading on the topic from CFD textbooks (or even wikipedia is a good place to start) and then ask any questions you might have on the forum. |
October 23, 2019, 07:27 |
#20 |
Rep Power: 10 |
Hi dear friends
I'm investigating a 5blade propeller. I have to calculate the thrust of one blade for different angles of rotating.for example thrust of a blade at positions teta=0, teta=5, teta=10, ... , teta=270 . How we can do it? |
cfd - post, force, function calculator |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
User CEL Function and CFD Post | chastain | CFX | 4 | September 24, 2013 13:58 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Poly lines in CFD Post | ashtonJ | CFX | 0 | December 2, 2010 02:46 |
