Nick Osbourne
Rep Power: 0 ![]() |
Hello everyone,
I am attempting to simulate a horizontal axis tidal turbine in Ansys CFX. The process I have taken so far is below: I created a simple geometry in Solidworks and imported into Ansys Geometry. I created the fluid domain and used boolean subtract for the turbine. I've attached an image of the fluid domain, which consists of two stationary domains (inlet and outlet) and one rotating domain. For boundary conditions I have: Inlet: Inlet Outlet: Outlet Outside walls: Free slip walls Turbine walls: No slip walls Interfaces between stationary and rotating domains: Frozen Rotor I have run both steady state and transient scenarios. I am using the Shear Stress Transport turbulence model. I have a constant inflow velocity and have set angular velocities for different cases to achieve specific tip speed ratios. In CFX-Post I utilized the integrated torque function on all of the turbine walls. Then to get power you simply multiply the torque by the angular velocity. I've attached an image of the streamlines from one of the steady state scenarios. My Questions/Issues are: 1) My Power output that I am reading is far too high (I'm getting Cp values around 6.5) 2) With the transient solution I would expect to be able to create an animation and see the turbine domain rotate. I am however seeing no visual change between timesteps. I am wondering if this is due to the coordinate frame of reference being linked to the rotating reference instead of the stationary's? I feel like I am either missing an important step, or am misunderstanding a step I have already made. Is there someone with experience that could shed some light for me? Much appreciated |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Accuracy is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
To get the rotor to rotate in a transient simulation you need to use Transient Rotor Stator in the interface parameters. Frozen rotor assumes the rotor is frozen (obviously). |
Nick Osbourne
Hello Ghorrocks, thanks for the reply. I have read through some of the FAQ, in particular the "Why are my results inaccurate" section, and found them quite helpful. Thanks for the tip about the Transient Rotor Stator option, I hadn't noticed this was available for transient solutions.
I will update once I do some trouble shooting. |
ansys, cfx, tidal, turbine |
Simulation of Wind Turbine with OpenFoam | be_inspired | OpenFOAM | 52 | September 6, 2018 10:33 |
Vertical axis wind turbine simulation | vincentwks | ANSYS | 0 | April 10, 2012 04:27 |
I read, did, searched and still not get the result, pls help me out my tidal turbine | altomos | CFX | 7 | March 31, 2011 10:08 |
wind turbine simulation | moca | CFX | 1 | July 25, 2009 06:48 |
cfx turbine simulation | mehrdadeng | CFX | 0 | March 31, 2009 05:08 |
