March 5, 2014, 12:31 |
Transitional flow (Gamma Theta model)
Majid
Rep Power: 12 |
Hello everyone
I had a question regarding transitional turbulence option and particularly the Gamma Theta model, for flow inside a pipe is it possible to treat the flow near the walls as turbulent and in the middle portion as laminar with a transition region in between for the entire pipe length, from the description of transitional flow I concluded this but I am not sure if it is correct, Thanks |
March 5, 2014, 16:37 |
Rep Power: 143 |
This is exactly what the transitional turbulence model does. The only caveat is that the Gamma Theta model was developed for external flow especially on airfoils, so you have to be careful applying to internal flows. But give it a go and just do a careful validation... which you were going to do anyway, right?
March 6, 2014, 10:16 |
Majid
Rep Power: 12 |
ghorrocks
Yes of course I validate the results, So far I am getting good results although I found this method extremely sensitive to IC. and BC.s but after trying a few different settings I got good results Thanks |
March 6, 2014, 15:59 |
Rep Power: 143 |
That is good to hear - and I am not surprised it is sensitive to IC and BCs. Good to hear you have checked this.
gamma theta, transitional flow |
SST turbulence with Gamma theta and Boussinesq model | kmgraju | CFX | 2 | June 11, 2013 00:46 |
Transition Model - Gamma Re Theta | nomad | STAR-CCM+ | 5 | April 17, 2011 08:34 |
Coupled Flow model | RalphS | OpenFOAM | 1 | November 15, 2010 03:51 |
Gamma theta model | Daveng | CFX | 0 | June 25, 2008 10:11 |
