April 30, 2014, 11:29 |
Reversed flow over airfoil in ANSYS
Shoaib
Rep Power: 12 |
I am simulating flow over an RAE2822 airfoil with forward sweep configuration.
After applying all boundary conditions, when I run the solver, everything is normal except in post processing, the lower pressure is on the lower camber of airfoil instead of upper camber. The values seem logical and correct except that they should be on opposite cambers. I am confused about this. Any suggestions and advice would be really appreciated. |
April 30, 2014, 19:01 |
Rep Power: 143 |
Are you sure you have the angle of attack right? The airfoil looks pitched down to me, and that would explain the low pressure on the bottom side.
May 1, 2014, 02:54 |
Shoaib
Rep Power: 12 |
It is a twisted wing where the tip is at angle of 11 degree with the root. And the wing is kept at an angle of attack of 1.5 degrees.
Even if the wing is pitched down, the pressure has to be lower on the upper surface to produce lift. The situation in the picture would mean that the wing will drop down more instead of lifting in this condition which makes no sense. |
May 1, 2014, 09:10 |
Rep Power: 143 |
If the wing is twisted then one section of the wing can produce upwards lift and another produce downwards lift.
May 1, 2014, 21:43 |
Shoaib
Rep Power: 12 |
I changed the angle of attack of the wing to 3 degree and still getting the same result.
Any advice |
May 1, 2014, 21:50 |
Rep Power: 143 |
I still think what you are seeing is real.
But your question really is "I think my simulation is inaccurate". That is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F There are millions of benchmark results for flow over airfoils. You should do a validation that you can accurately produce the lift and drag of a foil you have good benchmark results on before attempting your configuration. Otherwise how do you know whether your result is accurate or not? And this is exactly the problem you are now in. |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Reversed Flow in Outlet | Steve | FLUENT | 18 | March 30, 2013 07:50 |
Reversed flow cyclone | Mohsin | FLUENT | 0 | August 7, 2012 20:46 |
About the invisd flow around an airfoil | maximus | Main CFD Forum | 1 | July 16, 2005 15:04 |
